The documentation states: If the email is going to be sent by the OL Connect SendGrid plugin, the X-SMTPAPI header will not be used. Enter the category or categories in the plugin’s settings instead.
I don’t want to change categories, but I’m guessing that’s the problem since I use this plugin.
The question is can I add custom arguments with SendGrid plugin (and how)?
If it’s not possible, the next question would be how to send mail to SendGrid without this plugin?
Info: Notice the difference? The start of the line of JavaScript code changed from merge.context.sections to merge.template.contexts.HTML_EMAIL.sections.
I don’t believe the custom_args property (described here) is supported by the SendGrid plugin in Workflow. There is no way to pass a value for it.
I’m not that familiar with OL Connect Automate but it doesn’t look like it is supported by the SendGrid node in Automate either.
I can’t come up with a workaround. Perhaps someone else can help out.
Edit: This was the result of tracking down and analyzing the source code. The Workflow plugin has a comment saying we should look into adding support for custom_args, but there was no ticket yet. I created a ticket now; internal ref SHARED-94452.
