I am trying to run a data mapper process to import UTF-8 pipe delimited data files which can contain emoji’s and other non-standard characters which are still supported in UTF-8.
When I am running the data through my development VM the data imports/outputs without problem.
When I take the same configuration and data files and run them on the production system I receive the following error:
[0024] W3001 : Error while executing plugin: HTTP/1.1 500 There was an error running the data mapping process caused by ApplicationException: Error executing DM configuration: DB Error during DM result persist worker (DME000150)
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.7.7.v20200504-69f2c2b80d): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.BatchUpdateException: Incorrect string value: ‘\xF0\x9F\x91\xA8\xE2\x80…’ for column ‘DATA’ at row 7
Error Code: 1366
Error Code: 1366
Incorrect string value: ‘\xF0\x9F\x91\xA8\xE2\x80…’ for column ‘DATA’ at row 7 (DM1000031) (SRV000012)
There are no columns named “DATA” and the file is only 2 rows long, 1 header row and 1 data row
Connect can use the default database (installed by Connect installer) or an external database that can be installed/created by other tools. Even if Connect uses the default database (installed by Connect installer) it can be different depending on the version of Connect.
You can verify database schema properties: character_set_database and collation_database on both machines.
To verity these properties you can run a query on database: USE objectiflune; SELECT @@character_set_database, @@collation_database;
To run the query you can use a cmd prompt or MySQL workbench.
To run the query in command prompt you can open cmd or Windows PowrShell and do next:
cd “C:\Program Files\Objectif Lune\OL Connect\MySQL\bin”
mysql.exe -u root -p
… provide a database password for MySQL database (the one that was used during installation)
once you are in mysql promt run query USE objectiflune; SELECT @@character_set_database, @@collation_database;
Normally to support the emoji’s and other non-standard characters the collation has to be utf8mb4_unicode_ci and charset utf8mb4
I have gone through and made those modifications, i have verified it is showing the expected encodings when following the instructions from Andriy, but it still is erroring when running the data.
I went in and ran alter commands on all individual tables as well, but it still doesn’t seem to show any improvement.
It is possible that even if you alter the charset of existing objectiflune schema, existing tables has the old charset.
Probably it will be easier just to create a new schema with expected properties with next query:
CREATE SCHEMA objectiflune2 DEFAULT CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci ;
After this you have to change Preferences in Connect (Designer and Server) to point to new created schema: objectiflune2 instead of objectiflune.
Note: After changing the name of schema in Connect preferences, try to restart OLConnect_Server, so all tables will be automatically generated in new schema.
After creating and making the change to “objectiflune2” connect designer no longer opens. I get the splash screen, but then it goes away and the application never opens. I can revert the setting in server configuration and then it will open again.
What is the version of Connect on the problematic machine?
In my test I just change the name in Connect Server Conviguration->Database Connection->Schema: to not existing schema (ex: objectifluneX). Then I restart OLConnect_Server, and it automatically creates the schema and tables.
But I think in your case, by default it will create utf8 charset instead of utf8mb4.
Is it installed independently from Connect installer?
I think in Connect 2020.2.1 we install MySQL Ver 8.0.18 for Win64 on x86_64
Server Version 5.6.25 MySQL is dated 2015-05-29 and it can miss some important features comparing to MySQL Ver 8.0.18 (2019-10-14).
It depends what you choose during the installation. You can select MySQL installation or not. It is possible when Connect 2020.2.1 was installed the check box “MySQL” was not selected.
I think this is the main reason why we have different behaviour.
Definitely it is better to use newer version of MySQL. But if you prefair to continue with 5.6.25, you have to ensure that the actual schema/tables/columns have expected charset.
If the machine is not in production and you want to update the MySQL. Probably the cleanest way will be to Uninstall Connect (with MySQL) and Install it again with MySQL checkbox selected.
