XML level for datamaper
I have a datamaper witch read xml file. it’s for editing one PDF each time with a PReS connect template. the structure is like that :
Now I whant to use the same template but for many edition. The xml file have the same structure but with a root level add :
It’s dirty but I can’t change the name of the original tag…
So can I use the same datamaper and how ?
Thanks.
I think you just need to change in your datamapper settings the xml elements to trigger a new record, which for your new structure needs to be /ROOT/root.
