I have some XML data where the second element is defines each row, but multiple rows belong to a document. There isn’t any organizing element between the rows for multiple documents are all organized on the same level
Looking for ideas.
Looking for ideas.
You’d think there’d be an easy XPATH statement to do this, but it turns out to be quite the challenge … which I wasn’t able to solve, unfortunately
However, you can write an XSLT transform and apply it in Workflow before sending the data file to the DataMapper:
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet version="2.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output method="xml" version="1.0" encoding="UTF-8" indent="yes"/>
<xsl:template match="/">
<Start>
<xsl:for-each select="//Start/row[not(reference = preceding-sibling::row/reference)]">
<xsl:variable name="current" select="reference" />
<record>
<xsl:apply-templates select="."/>
<xsl:for-each select="following-sibling::row[reference[text()=$current]]">
</xsl:for-each>
</record>
</xsl:for-each>
</Start>
</xsl:template>
<xsl:template match="@*|node()">
<xsl:copy>
<xsl:apply-templates select="@*|node()"/>
</xsl:copy>
</xsl:template>
</xsl:stylesheet>
This code wraps all related elements inside a new <record> element, which then makes it easy for you to set your record boundaries in the DataMapper.
At first it didn’t seem to work, but then I noticed your XSLT script had the node REFERENCE as lowercase reference.
<Start>
<xsl:for-each select="//Start/row[not(REFERENCE = preceding-sibling::row/REFERENCE)]">
<xsl:variable name="current" select="REFERENCE" />
<record>
<xsl:for-each select="following-sibling::row[REFERENCE[text()=$current]]">
</xsl:for-each>
</record>
</xsl:for-each>
</Start>
</xsl:template>
<xsl:copy>
</xsl:copy>
</xsl:template>
</xsl:stylesheet>
Thanks, this looks much more manageable in the data mapper!
If I needed to sort the records by the REFERENCE number, where would be the best/easiest place to do this?
You could use another XSLT, after the one you already implemented. Something like the following should work:
<xsl:stylesheet version="1.0"
<xsl:output omit-xml-declaration="no" indent="yes"/>
<xsl:template match="node()|@*">
<xsl:copy>
<xsl:apply-templates select="node()|@*"/>
</xsl:copy>
</xsl:template>
<xsl:template match="/Start">
<xsl:copy>
<xsl:apply-templates select="record">
<xsl:sort select="./row/REFERENCE" data-type="number"/>
</xsl:apply-templates>
</xsl:copy>
</xsl:template>
</xsl:stylesheet>
Thanks, I need to learn more about XSLT
