Workflow service not work
It is a simple process,capture txt file in “c:\in” and send to “c:\out” ,when i run it not working.i already set process as soon as possible.
Hello Tom,
Welcome to OL User Community! Did you make sure your services are started?
You should check the Maskthat is setup as well as if your file are hidden or empty (there are checkboxes for those case.
Could also be that those files still have a hold by some other application. In that case, try to do a copy paste of the file directly in the same folder. If an other app as a hold on it, it will error out.
