Hi All
I have a strange issue with workflow .Whenever I try to run or edit a script action Workflow hangs . The only way to recover is to go into task manager and close it .
So far I have tried the following
- Upgrade OLConnect/Workflow
- Uninstall/reinstall OLConnect/workflow ( many tims)
- Create a new config file ( deleted the old one )
- created a new ppwatch.cfg file
- Disable all unused processes
- Delete all install folders and try remove any remains of the old installation
- I tried the hold down “CTRL/SHIFT” when starting workflow
- None of the logs show anything that I can see as an issue
All plugins work fine except for the “Run script” plugin . Running the latest versions .
Mark
