I understand that PlanetPress Classic workflow will not work in Windows 11 but will the designer install and function in Windows 11?
PlanetPress Suite has not yet been certified on Windows 11, but I can tell you (unofficially!) that I’ve been running the PlanetPress Designer on WIn11 for several months now without a hitch.
So… use at your own risks: since the OS has not been certified, Support may not be able to offer you help if you run into issues. But I have yet to run into any issues…
Thanks Phil. It will come in handy when moving Classic Templates to Connect Templates.
It would be nice if there was a version of the Classic designer that could be loaded on a OL Connect server at any point (even after OL Connect is already installed) that would allow sending forms to the OL Connect workflow directly. Instead of the export/import process.
This would be for customers who have lots of forms that they have decided to not recreate because they are only used occasionally or because they are lower on the priority list.
It can work but you have to install PlanetPress Classic first and then Connect.
It has to do with shared file that overwrite upon installation so you need Connect to be installed the last so it works properly.
We’re working on it as we speak. But shhhhhh… you didn’t hear it from me… ![]()
