I have a text file with more than 1000 records but everytime I reload the data.
The record count changes sporadically.
I dont understand this.
Appreciate any help.
Kind regards,
E
Kind regards,
E
That’s a display issue we are currently investigating. It mostly occurs with Excel files (XLS, XLSX), but strangely enough it doesn’t appear to be common when the initial data format is CSV.
That said, when the job is actually executed (from the Workflow engine, for instance), then all records are properly processed. So it seems to be just a display issue in the DataMapper module, but resolving it has eluded us so far.
Hi Phil,
We mostly deal with CSVs. And I can report for large number of records this is apparent. And seems to do that all the time.
This is frustrating among other things.
But I see that its being looked at.
Hopefully next update its fixed.
Thank you
Kind regards,
E
Note that it may not be addressed in the upcoming 2024.2 release as we are nearing completion of the development cycle for that version.
Still, I have marked the issue as high priority. (internal reference: SHARED-91868)
