Weird embedded font names and garbled text: HPBAOP IAGCCN IAGCCO EDWADE
A Connect workflow produced a PDF file that shows correctly on screen but can’t be printed.
If I inspect the fonts in the page I get the following list.
name                                           type              emb sub uni prob object ID
HPBAOP+Arial                                   TrueType          yes yes no         2911  0
IAGCCN+Arial                                   TrueType          yes yes no         2828  0
IAGCCO+Arial,Bold                              TrueType          yes yes no         2831  0
EDWADE+LucidaConsole                           TrueType          yes yes no         2830  0
What are those prefixes in the font names? I can’t find any documentation or information on their meaning.
Furthermore, if the fonts are embedded, why would the printer print empty boxes?
These names indicate that the fonts are actually a subset of the original. This is done to reduce the file size. There may be multiple subsets of a font, where each subset is identified with a random sequence of letters. For example here you can see that there are two distinct subsets of the Arial font.
Thanks for the clarification @fortiny!
I’ve updated my main post with more details before noticing your reply.
I repeat my edit here:
If the fonts are embedded why would the printer print empty boxes on the page? I’ve attached a scan of the printed document in the first post.
My first thought was font permissions, but those are standard fonts which usually allow all operations. Perhaps there is a mixup with the printer driver involving font substitution.
  • Which software are you using to print?
  • To which printer driver?
  • Have you tried printing to another printer?
  • Can you give more details about how the PDF file is produced in the first place? One important detail would be what is the nature of this text. Is it part of a PDF picture or background or is it a text object?
  • Is the source a legacy PlanetPress form or a Connect document? Or other?
Tried to print with three methods:
  1. Printer: IM C3000 RICHO - office printer with no built-in raster image processor
    Document printed through Adobe Acrobat printing dialog using the provided printer drivers.
    The document is correctly shown on screen
  2. Printer: RICHO RISO COLOR, this is an industrial printer with a built-in RIP
    Document loaded to the printer hot folder for printing. No drivers involved from computer to printer, it’s the printer itself that does all the job.
  3. Printer: IM C3000 RICHO - same as point one
    I’ve re-saved the document using Adobe Acrobat optimization and printed the new document. This, as of now, is the only way to correctly print the document.
We have several other industrial printers, but they all run on the same RIP software (Efi Fiery)
It’s a PDF we receive “as is” from a client, the planet press Connect Workflow involves a bare bone template which adds barcodes for the enveloping phase.
The source document is created by iTextSharpTM 5.5.13 ®2000-2018 iText Group NV (AGPL-version) (based on the original document metadata).
The important thing to note is that the original document prints correctly on all the printers, it gets “screwed” only after passing through the Connect Workflow
Hi @Maxiride,
What about checking the option “Pass-through PDF resources” in the PDF options window of the Output Creation wizard? Have you already tested if checking this option does result in the same issue?
Pass-through PDF resources: Click to have PDF resources used as-is, without any additional processing. This guarantees the fidelity of any PDF graphics used within the template will be retained in the output.
This option is only available for standard PDF output.
Source: ‘PDF Options - PlanetPress Connect 2022.1 User Guide (link)’
I opted to open ticket, id 1107972
I’ve attached all relevant files.
Hi @Maxiride, did this ever get resolved?
I have got a kind of similar issue with the one you are having, was wondering if you ever hot to the bottom of this issue?
