Web Fonts from data
Hi there,
Is it possible to pass a google fonts url from the data file into a template?
I’m setting up a print job from a client’s web application where they are suppling the data as json. I have the google fonts url in the json.
This google font will be static for each data file but could be different for each data file we receive.
Michael
Hello @MichaelEngstrom, for what content type would you like to include these dynamic web fonts? Is it for web content, for example? Because for web content I expect this to be possible but not for print content.
Standard Script
Selector: head
// Replace '#' with the correct URL
var result = '<link rel="stylesheet" type="text/css" href="#">';
results.append(result);
HI Marten,
Sorry I should have said this is in a print template.
Is there likely to be some other work around for print context?
Is this something that could possibly be added to print contexts in the future?
thanks Michael
I don’t see why this would not be possible for a print template, but you’ll probably need to embed a <style> element rather than adding a <link>.
The following standard script with selector “head” seems to work fine:
const url = "https://fonts.googleapis.com/css2?family=Roboto:ital,wght@0,100..900;1,100..900&display=swap";
const family = "Roboto";
results.append(`<style>@import url('${url}')</style>`);
query("p").css("font-family", family);
This is just an example with static data, but url and family can be pulled from fields instead.
Hi, just confirming that this seems to work in print templates.
