W4230 - Metadata does not contain a valid Job Item Collection in create output
I have a connect process that takes an XML and produces a document. I created two output presets, one to create a PDF and send it to a directory and one to send output to a printer. The create output objects bothe get the “W4230 - Metadata does not contain a valid Job Item Collection” error.
What can be causing this?
  • the process executes the correct data mapping
  • it then creates print output using the correct template
  • it then branches to one create output then continues to the second.
One reason for this error could be a missing Job Creation task which needs to run before ‘Create Output’.
As Martin says it is usually a missing Job Creation Preset. If you don’t have one or need one and are using the Create Print Content Plugin the you need to select Update Records From Metadata. Although in my experience that way is generally slow. Best to use the All In One Plugin that Rod here advised me about as it generates PDF’s allot quicker.
I know this looks to be an old thread but I just had this problem. Tracked this to a misconfigured template control script. The issue seemed to be that no print contexts ever got enabled in the control script. The Mapping, Create Print Content & Create Job plugins all seemed to run without error - just the Create Output plugin that threw the error. Once I’d tweaked the control script to enable the required print context the error went away and this seems to have resolved things (btw I’m using 2018.2)
I hate to bump a dead topic, but this error seems to keep rising from the grave like a zombie.
I have had this error in my Output Preset as well. I created a simple process that is currently meant to separate a PDF file into individual PDF documents based on the boundaries set in the DataMapper. I have all the elements, including a Template that currently does nothing, and in Debug everything seems to work until the Create Output plugin.
What does this error mean? What is Job Item Collection? Where should I look to correct it?
One of the possible reasons why an W4230 error occurs is that the Create Job Workflow plugin, with or without a job preset applied, was not executed before the Create Output Workflow plugin.
Workflow example:
Execute Data Mapping → Create Print Content → Create Job → Create Output
