W3001 DataMapper Error
I am getting the following error
18:36:32.545 [0004] W3001 : Error while executing plugin: HTTP/1.1 500 An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the data mapping process caused by ApplicationException: Error executing DM configuration: The step is out of bound (DME000130) (DM1000031) (SRV000012) (SRV000001)
18:36:32.545 [0004] Execute Data Mapping: W1603 : Plugin failed - 18:36:32 (elapsed time: 00:00:00.793)
Any suggestions?
Hi @langan.j,
Looking at one of the error codes (DM1000031) suggests there is an issue trying to perform an extraction in the datamapper. I cannot tell is you are using a TEXT/CSV/PDF datamapper template. Try to validate the datamapper and your data file by clicking this button in the datamapper. It will tell you what record is giving you this error.
For this to work you will need to set the maximum record count in your datamapper
Hey @james123456,
It is a .txt file.
Thank you for your suggestion. The validation button has shown me the problematic records.
I’m guessing they would have to be removed and mapped separately - all records share the same format so quite confused as to why.
I forgot to say, Welcome to the OL community!
If you have records that differ, you can start your mapper with a condition step to cater for both record types. (if you can differentiate the two).
Much appreciated @james123456
Great idea - thank you @Sharne
