Vertical Spacing in Positioned Box
Hello all,
I have text inside a positioned box that needs to fit within an area. To do that I need to adjust the vertical spacing to make the height slightly shortly. How do I successfully do that?
Hi Rolf
You can do this using the copy fit function in connect designer. To do this create a div/box, add your text and data elements then size it to fit.
Once you’ve done this right click on the div and select box form the box formatting screen select the content tab and then check copy fit. The box will now automatically resize the text in it to fit based on the font sizes you’ve specified.
You can read more about this in the help here.
Hope this helps
Alex Banahene
