Hello, I can’t get a variable that is seen correctly in DataMaper to be seen as Metadata in WorkFlow, I am providing screenshots.
When I want to read this variable (AcuAlbaran) in the WorkFlow it always comes out blank.
thank you and greetings.
Can you share your Datamapper with anonymized data?
Hello, I can’t attach more files, it only leaves me one.
I am a new user.
Moderator: File removed because it contains identifiable data.
There was an error in yuour script where you forgot to set the [e] next to the …tables.InFoAlbaran[e].field…
_AcuAlbaran="";
var tmpStr;
tmpStr="";
for(var i = 0; i < record.tables.detail.length; i++) {
if(record.tables.detail[i].tables.InfoAlbaran){
if(record.tables.detail[i].tables.InfoAlbaran.length > 0){
for(var e = 0; e < record.tables.detail[i].tables.InfoAlbaran.length; e++) {
tmpStr = record.tables.detail[i].InfoAlbaran[e].fields.N_Albaran.trim();
if(tmpStr == ""){
tmpStr = "XXXXXXXXX";
} else {
_AcuAlbaran += "," + tmpStr;
_AcuAlbaran;
Your datamapper configuration is looking for Nº in order to extract the N_Albaran value.That works well in the DataMapper itself, but in Workflow, your data has gone through the Translator task, which converts that data token to “N?”:
So instead of looking for Nº, your Caso4 condition should look for Pedido, and then everything works as expected:
Thank you very much, I have tried it and it already works, thank you again, I didn’t know what to do to solve it.
It’s already resolved, thank you very much for your help.
