using xml splitter and text condition in workflow
Hi - I am using an xml splitter to break up my data in workflow. It seems to work fine because when I step through the process I see where it produces 6 files. I have this placed right as the the second action to take. Then it goes through the rest of the process (datamapper, template, creating the metadata files). No problem or errors here either. I then have a text condition to say if field equals ‘P’ sen it to this folder otherwise go to another folder. My problem is that it only produces one PDF file. This pdf is the first one in the data. I can’t seem to get it to produce the other five pdf’s.
Does anyone have any suggestions?
Have you tried taking each and every splitted files and try them in the Template/Datamapper and print a PDf out of it?
Yes - and they all produce a single .pdf when run through designer separately.
When you are going step-by-step, when it goes out of the OutputCreation Connect plugin, just before it goes into the condition, if you click on View PDF…what do you get?
I get the first PDF that I am supposed to get. This example only has 6 PDF’s for testing so I stepped through again and viewed as PDF. I see the second PD as I should. I then finish stepping through and there is no final output for the second PDF.
And the others…they give an error or simply there is no other? If they give an error, have you tried to look at them as text?
no error. just nothing. At first I thought they were being over written when being saved but the names are definitely different due to the data selection being on SSN.
It would be best to remote in to check all of this live. Please open a ticket. I am the only one left now so it will be assigned to me. I will wait.
ok - doing it now
Thank you
