User define templates with fields mapping
Dear All,
I do have a request from user, to automate a letter generation using OL Connect.
However, this letter template is not fixed and fields mapping in the template is required.
Which means, during every batch run, user will provide the template (either in word / pdf file format) and database (OL Connect to retrieve data to map into the template).
Appreciate your advice on how to fulfill this requirement using OL Connect.
Thank you very much.
Janice
If by that request you expect to “automate” the mapping, field positionning in the Template, then it is not possible. That would require AI which has yet to be integrated…if ever.
If this ins’t your request, please explain more in detail what you are trying to achieve.
