Hi
I need to use the original record index number before the Trigger Change is applied!
This is for cross matching with a URN across other templates which use the same data but without Detail tables.
Joe
Hi
Joe
Hi Joe,
You should be able to extract this from your data so you can use it in workflows and templates, but we’d need to know more about your dta (i.e. what type of data you are using, How its structured and where is the URN you’re looking for within that data)
Alex Banahene
Hi Alex,
Thanks for getting back to me so promptly.
To answer your questions, I’m using a xml data file.
Sorry I haven’t explained the problem correctly.
I have two Datamapper and Templates which both use the same xml data, one is using ‘Boundaries’ Triggers - field ‘con_id’ - to create a detail table so the record count is less than the other datamapper and template which uses no ‘Boundaries’.
Because the record.index numbers don’t match up, the only way I can have a record match is to have a ‘detail table’ sequence number after the top level Sequence number so ‘1.1’ then ‘1.2’, then 2.1, 2.2, 2.3, (the first number being the top level Seq number and second number being the detail sequence number). Or to repeat the record index number when there is a match on the ‘con_id’. The only problem with this is that this datamapper for this Template doesn’t use a detail table and is one print per record.
If it helps I’m using a Workflow to run this job.
Any help would be great.
Joe
Hi joe,
I think this would be best answered as a formal support ticket, so if you haven’t already please cna you one a ticket with your local support team.
Alex Banahene
