To expedite process of PDF email attachment.
I’m currently run email with attachment and seeing that the process a little bit late as usual.
May I know meaning of this “The PDF generation is repeated for each record. It is possible to run datamapper, template, job preset and output preset once and then generate the PDF in individual file (split by each record) instead of existing method which is run datamapper once, then repeat template, job preset and output preset for each record.”
There said that need to setting at output preset, may i know which part of job preset need to setting.
TQ..
Hello @azlah,
Would you like to split PDF output into multiple files? If yes, then I assume that the Separation options is where you are looking.
Tip: See Print presets - OL Connect 2025.1 Help for more information.
