Text Script formatter
Can anyone provide an example of how to format negative numbers to use a leading negative sign (dash) instead of enclosing them in paranthesis?
By default the “formatter.currency(field);” method will put “()” around negative numbers. I’m sure there is a way to supply a different, custom pattern, but I’m not finding it in the Help system.
Have you read this and then this?
In scripting it would look something like this:
results.text(
	formatter.currency(record.fields.value, "#,##0.00 €; -#.##0,00 €")
When using expression something like this:
{{number value "#,##0.00 €; -#.##0,00 €"}}
Note that the standard formatting follows the Locale set for the template. Things could be as simple as changing the locale in Edit > Locale to an explicit locale (assume your document is now using en-US but for example chaning it to en-CA would show the desired result). The formatting of dates is also influenced by the locale.
