We extract with the Datamapper a date field from a document. Till this morning everything goes oke, but now the date field is converted to the extracted minus 1 hour. For instance: the date is extracted to 2018-03-26T00:00:00Z, but now 2018-03-25T23:00:00Z. Is this a bug? or how can we solve this issue?
Have any of the locale settings on the workstation which runs Workflow have changed?
To confirm: the date in the data shows 2018-03-26T00:00:00Z but you get 2018-03-25T23:00:00Z?
Do you extract it as a date or as a string?
If as a date, what is the date/time format you have applied?
No locale settings are changed, the only thing is that the summertime is started this weekend.
We extract the date field from the document (2018-03-26), as a date in the date format YYYY-MM-DD. The date field is represented in the XML as a datetime like 2018-030-26T00:00:00Z, but now it is 2018-03-25T23:00:00Z. Any clue???
I just tried it here…I can’t seem to reproduce that behavior.
To help you properly we would need to see the Template and reproduce the issue. I suggest you open a technical support call at 1-866-348-5863 or through our website.
However, if you fo not have OLCare and your data is not sensitive, can you post it here so we can take a look at it? As well as you OL-Datamapper.
Best regards,
