For some background: for a while now we’ve been using a very simple PP7 Form to take PDF files sent into us and stick a date stamp on them and then print them, but recently one particular source of PDF files started printing blank pages (with the date stamp) instead. Opening the PDFs themselves doesn’t reveal anything particularly strange, they open in Adobe or Edge just fine. Investigating those PDFs specifically in Designer 7 showed the .PDF as having some sort of error, but for the life of me, I couldn’t find anywhere where it actually provided an error message.
Thinking that it might just the PP7 form not playing nicely with some newer PDF variant or something, I opened up Connect Designer to see if I could replicate the functionality with a more modern template. It seemed pretty straight forward – DataMap a PDF, set it as the background of a template, add a text box with the Date Stamp.
However, when trying to DataMap the weird PDFs that were giving us grief before, I’ve received a series of strange errors that I haven’t been able to find much reference to anywhere. When trying to use the weird PDFs as the base file for a new DataMapper Configuration, I get one of the two following errors:
Error converting file to PDF, please check the server engine ApplicationException: Unauthorized:(Unauthorized) (DME000202)
Error converting file to .PDF, please check the server engine WebApplicationException: HTTP 401 Unauthorized (DME000202)
If I select a different PDF from a different source, it creates the DataMapper Configuration fine. If in that DataMapper I then try to add one of the weird PDFs as an additional Data Sample, it gives one of the two the following errors instead in the Messages view:
Error initializing engine: Unauthorized:(Unauthorized) (Dm_1108)
Error initializing engine: {“error”:{“status”:401,“message”:“Failed to authorize with basic authentication provided. (SRV000100)”,“parameter”:“”}} (Dm_1108)
Sometimes they give one error, sometimes the other, not sure why the errors aren’t even consistent. Has anyone seen anything like these before? Am I doing something wrong, or is there some way of creating PDFs that this source is using that just doesn’t play nicely with PlanetPress / OL Connect?
Thanks!
