SQL: Add more than one result to datamapper
I actually try to add more than one sql result to a detailed table.
The action step is as follows:
var connectionURL = ‘jdbc:odbc:Driver={iSeries Access ODBC Driver};System=...;Uid=;Pwd=;’;
var sqlConnection = db.connect(connectionURL,“”,“”);
var sqlQuery = “SELECT * FROM . WHERE *** = ‘xyz’”;
resultSet = sqlConnection.createStatement().executeQuery(sqlQuery);
resultSet.next();
resultSet.getRow();
The extraction step then looks as follows (detail.table):
let testExtract;
resultSet.next();
testExtract = resultSet.getRow() ? resultSet.getString(“WB_COLUMN”) : “”;
I know that the return of the select has more than one record, how can I add them to a detailed table?
Many thanks.
NBecker
You can’t add multiple rows using a script (that feature is on our roadmap, however).
So in the meantime, you’ll have to store your rows in an array and then use a Loop step to add each element of the array to the detail table.
Thanks for your answer, is there an example how this works?
Loop through your record like this, adding each record to an array:
var myArray = [];
while( resultSet.next() ) {
   myArray.push({
      lName : resultSet.getString("LastName"),
      fName : resultSet.getString("FirstName"),
Now in your config, use a Repeat Step inside which you add an Extraction Step. To extract all the “LastName” fields, as in the example above, set the mode to JavaScript and user the following code:
myArray[steps.currentLoopCounter-1].lName;
In your Repeat step, make sure you set the Maximum iterations on each line value to
myArray.length
This should get your going.
Hi Phil,
I’m able to exctract fields following your suggestion by creating the array and then extracting the fields.
The problem is that i have a specific use case where i loop through a table populating its content which is inside another table, meaning that if i switch between items of the parent table also the child table is updating(data all extracted from sqlserver). It seems like when i try to extract the fields from the nested table by following your suggestion each time i go on the next loop cycle it loses the last item from the composed array containg the data.
Is there a way to not lose items from the declared Array when the parent item iterates to the next loop cycle?
Thanks.
M
Hi Muno1, and welcome to the community!
This post is fairly old and since that time, there have been a number of improvements to the scripting methods that allow you to add multiple rows to a detail table. Search the Forum for the keyword addrow, and you’ll find a few posts and examples (in particular, this one).
Hi Phil,
That solved the problem right away!!
Thank you!
