I’ve created my “Job Creation Settings” and my “Output Creation Settings” so that I get a separate output file based on the change of a specific field. It works correctly as long as I don’t select “Imposition”. If I select “Imposition” and create a multi-up document I only get a single output file. I am trying to create a output file for records based on their mail tray identifier.
The original boundaries between the records are ignored when you use imposition. In order to create different documents, you can first split the data based on that field and then create the output. Let me know if you need help on that.
Best regards,
Eline Hendrikse
