is it possible to split output based on a metadata group (e.g. all records with the same number in a field) and also based on sheet count (e.g. split all 1000 sheets).
Example:
There is a data field “NR” with a recurring value that changes from a certain record. Each record consists of one sheet.
Value “NR1” applies to the records 1 - 2500
Value “NR2” applies to the records 2501 - 3000
Value “NR3” applies to the records 3001 - 3100
I want to group the output based on the “NR” field and separate them accordingly. At the same time, however, a group have a maximum size of 1000 sheets or, if a group has more than 1000 sheets, an intermediate separation is to be made. For each separation a separate PDF file should be stored.
File 1: “Outfile_NR1_1.pdf” (contains sheet 1 - 1000)
File 2: “Outfile_NR1_2.pdf” (contains sheet 1001 - 2000)
File 3: “Outfile_NR1_3.pdf” (contains sheet 2001 - 2500)
File 4: “Outfile_NR2_1.pdf” (contains sheet 2501 - 3000)
File 5: “Outfile_NR3_1.pdf” (contains sheet 3001 - 3100)
PS: File naming can be different as long as it is unique (NR value) and in the correct order.
Can this be implemented without workflow in Connect Designer output?
