Split Datamapper Fields or Possible to sort data by lastname in workflow?
Hi Guys,
I just want to know if how can i possible determine and split firstname and lastname ?
Because our client need to sort the output pdf thru lastname so thats the solution (above) i know for now. Need your suggestions guys
Thanks,
g
Hi ggan,
For splitting dm fields, you`ll have to create two fields within your extraction and set their type to javascript. then write javascript syntax using the following two methods:
Please check this example : split_dm_fields.OL-datamapper (3.1 KB)
Hope this helps!
Best,
fsh22
