I am giving input PDF file and adding datamatrix using output preset. I do not want to change the order of the file so I have not added any sorting in job preset yet it is redoing the order.
FYI, I am not using Content creation here.
Can you let us know please what exactly is in the wrong order? For example, are the records produced in the wrong order once the job creation process has been executed? The reason why I am asking is because I assume that you only have a single PDF file as input.
I am providing the single input pdf that has 2000+ pages with different records like 1500 records where each record can have multiple pages.
I am not doing additional sorting as I want output should be in same order as input. like first page of input should be first page of output file.
Thank you for your reply. Given the information provided, I assume that it is the best to submit a support ticket via our support portal for this as a remote session may need to be scheduled to discuss the issue you are facing.
