[solved] Is it possible to create a background pattern in css?
Hello there!
I was just wondering is it possible to create a background pattern instead of solid colors in CSS?
Like the below:
Obviously Im going to use it to paint my custom bar graphs. On close up this is what it looks like
Now that I think about it, maybe I could make a repeating image of a pattern as a background instead?
Any advice is appreciated.
Thanks in advanced!
E
Unless you’re using a background image and repeat this background image (1) it is unfortunately not possible to apply a background pattern to, let’s say, a Positioned Box element.
Can you let us know please if you’re you creating you’re own Bar Chart element or the one which can be inserted by going to: PReS Connect Designer > Insert > Business Graphic > Insert Bar Chart? In case it’s the latest one I’ll have to inform you that it is unfortunately not possible to apply a background pattern to bar graphs (see ‘How to Apply CSS rules to Charts (link)’ for more information).
(1) Example:
HTML:
<div id="example"></div>
CSS:
#example {
    background-image: url('../Images/example.png');
    background-repeat: repeat;
    height: 200px;
    width: 200px;
Hi Marten,
Im creating my own bar graph. As I only need 3 bars without any other elements like the X/Y grid or labels etc. And I find the built-in graph generator to be difficult to use and customize.
And what I noticed too when using the graph creator, is when you are in preview mode as you edit its component and when you hit apply, it doesnt update the view which I found frustrating. Anyways thats just my take on it.
Thank you for the link you sent me.
And I indeed just used a background image like you mentioned.
Cheers
E
If you “draw” these bars as div boxes you can of course use css patterns as background.
e.g.
<div class="divBar"></div>
.divBar {
  background-color: white;
  background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' width='4' height='4' viewBox='0 0 4 4'%3E%3Cpath fill='black' fill-opacity='1' d='M1 3h1v1H1V3zm2-2h1v1H3V1z'%3E%3C/path%3E%3C/svg%3E");
  border: 1px solid black;
