[Solved] How to browse different copies of the same record?
Through the use of the Script API I’ve created multiple copies of every record and set some fields to different values.
The number of copies is correctly reported in the heading of the record browser but clicking the arrows moves through the records, how can I see the second copy of the first record for example?
PlanetPress Connect version 2021.2
You can not see the copies of a record in the designer. Only in the ouput the record will be copied as often as you defined it.
FYI. This is addressed in OL Connect 2025.1, see:
What’s new in OL Connect 2025.1
Awesome! And most importantly thanks for getting back to this thread to update us!
