I would like to print additional text consisting of:
- ${document.nr} = The sequence number of the document per document sets created.
- ${sheet.nr} = The sheet number per document
- ${document.count.sheets} = Total sheets per document.
This is all and good.
Is there a way I can control which pages they get printed? For example I want it to print on every odd pages eg: 1,3,5,7 so on.
Thank you.
Kind regards,
E
Aha nevermind!
Solution is inside the condition area I set it to:
page.front == 1
Now it only prints on front page only
Sorry for jumping the gun there!
Just a follow up to this.
This doesnt work if you have multiple sections.
It seems like the page.front==1 only applies to its current section.
Just for completeness. If you want to add the text on every odd page you can also use the following condition:
page.nr % 2 != 0
The additional text will be printed on every odd page independent of the section.
Same should be the case using page.front == 1. The pagenumber will be counted within one record (document) but over all sections within that document.
So if you have two sections, the first section with 2 pages and the second section with 4 pages, the document have 6 pages and your text will be printed on pages 1, 3 and 5.
If you need the text on every odd page independent of document page number (through the whole job), you can set the following condition:
page.sequence.job % 2 != 0
But than it can happen that your text will be also printed on a “back” side (document even page)…
Or what do you mean with “it doesnt work if you have multiple sections.”?
Yep.
Thats what I ended up doing (or I just make sure my document has even pages)
Thank you
