simplify javascript count
I’m creating a total count in my datamapper, but this is alot of repetitive scripting which I think can be much compacter.
This is a sample of the code:
var counter = parseInt(record.tables[“detail”][steps.currentLoopCounter - 1].fields[“count1”]);
if(!isNaN(counter)){
dagTotaal += counter;
counter = parseInt(record.tables[“detail”][steps.currentLoopCounter - 1].fields[“count2”]);
I need to add twenty of these addupps.
Is there a way to simplify this code?
thank you in advance.
Perfect spot to use JavaScript’s array.reduce method:
var flds = ['count1,'count2','count3','count4']; // add all field names here
flds.reduce( function(accumulator, currentValue) {
   return accumulator + (data.extract(currentValue,0)*1);
},0);
You’ll have to adapt to your own needs but that’s the gist of it. You can read up on reduce() here: Array.prototype.reduce() - JavaScript | MDN
Hi Phil,
Thank you, I didn’t use your script, but I solved it with the workflowplugin.
I also had some difficulties to fill the variable as the were in the detail table. the datamapper kept giving me an error.
var flds = [[record.tables["detail"][index].fields["count1"],record.tables["detail"][index].fields["count2"]]; // add all field names here
},0);
I think you could simply have used:
var flds = ["count1","count2"];
   return accumulator + (record.tables["detail"][index].fields[currentValue]*1);
},0);
In any event, if you found a working solution, then by all means keep it! :slight_smile:
thank you for your help,
I’m still learning each day about javascript so this is also helpfull in the future.
