I have a text file, full of six line addresses. I want to print them 3x11 (33-up) on a letter-sized sheet. I have designed my print section to be 2.83in by 1.00in.
The data contains a field that I wish to separate/sort by. These are US Department of Motor Vehicle labels, and the field has a vehicle type value.
The data is unsorted.
I want to SORT the data by Vehicle Type, and I want to Output a separate Document per Vehicle Type, and I want each Document to be 33-up.
I can do the SORT with a Job Preset, but I cannot get the Separation working in the Output Preset. All the labels print (sorted) within a single document.
I have Grouping by Document Set turned on within the Job Preset, and Separation by Document Set turned on in the Output Preset.
If I turn off Cut and Stack Imposition, the Separation works properly, and I get a separate file per Document Set (Vehicle Type).
But as soon as I turn on Imposition, the Separation fails and I get a single document with all Vehicle Types.
