Does anyone get an issue when trying to sending multiple mappers and templates at once to workflow? If I send just 1 of each it’s fine, but if I try sending 3 or more it looks like it’s sent but they aren’t showing in the list in workflow. I’ve reset the messenger service but it’s still the same
Yes i have had the same issue. A restart of the workflow service did the trick by me.
After the restart i’ve directly get the importing resources pop-up.
I have seen an old message from Phil mentioning that sometime a restart of the workflow services is needed. But this was when you push ol resources to workflow without using “send to workflow” from designer.
