Hello
I would like to send Classic design into Connect workflow (to use them inside Create PDF plugin) for PDF flattening.
Can You guys tell me how to do that?
Hello
Hi, to do so you first have to save the classic Dsign as ptz file.
Go on Send to Workflow and select save as file. You will then have a ptz file generated.
Now go on Connect Workflow, click on the Workflow button then Import - PlanetPress Document. Then select the ptz file and it’s done.
Thank You ![]()
That was fancy ![]()
