Most Scan softwares workflows, have the possibility to rename the output pdf file in a folder, if another file already exists in the folder with the same name.
The flows simply rename the pdf file _001.pdf, _002.pdf, _003.pdf etc., so no file is overwritten.
The plugin “Send To Folder” in the workflow can only overwrite the file or append existing file.
Do’s anybody have a simple script to do the task. The script should check the output folder for matching filename, and then return the extension for the new file like _001, _002 etc,
Then the script could be used just before the “Send To Folder”
Here’s a piece of code I wrote a while back that does what you’re looking for. I tested it quickly and it appears to work as expected.
CONST_FOLDER = "C:/Tests/Output";
CONST_FILENAME = "MyFile.pdf";
var fName = generateFileName(CONST_FOLDER, CONST_FILENAME);
Watch.SetVariable("fName",fName);
function generateFileName(folder,file){
var oFSO = new ActiveXObject("Scripting.FileSystemObject");
var oFolder = oFSO.GetFolder(folder);
var nameComponents = file.toLowerCase().split(".");
var fNameNoExt = nameComponents[0];
var extension = nameComponents[1];
var arr = [];
var fileFound = false;
var e = new Enumerator(oFolder.Files);
for (var i=0;!e.atEnd();e.moveNext()){
var fNoExt = e.item(i).name.split(".")[0].toLowerCase();
fileFound = fileFound || fNoExt===fNameNoExt;
arr.push(fNoExt);
if(!fileFound)
return fNameNoExt+"."+extension;
else {
var family = arr.filter(function(f){
return f.substr(0,fNameNoExt.length)===fNameNoExt;
if(family.length===1) {
return fNameNoExt+"_0."+extension;
} else {
var last = family[family.length-1].split("_")[1];
last++;
return fNameNoExt+"_"+last+"."+extension;
If stores the new file name (with a _xxx suffix if need be) in the process variable named fName. You can then use that variable name in your Send To Folder task. You’ll probably have to customize it a bit for your needs, but that should be fairly easy.
