I searched for an answer to this question for several days now, and most responses are going in a direction that does not work for me.
When we were using PP7 Suite we were able to generate a Print Summary page with counts that would print at the end of the job. I know this is not available with Connect, but I am hoping I can at least generate this information to an internal email when the job is done running through Workflow.
Basically I am hoping to get the the counts into the JobInfo Variables (%1-%9) so I can add them to my Send Email function.
I am seeing ways to pass info from Workflow to Connect, but not the other direction from Connect to Workflow.
I am hoping this is not all to vague.
The main projects I will use this for are PDF Datamapped jobs where all I am adding are datamatrix barcodes for our inserting equipment.
The PDF Datamapper is generating my Set Breaks, and Design is adding the Barcode and splitting the file by Sheet count 1-6 into a #10 envelope file, and 7-largest in a large envelope file.
