self-duplication processes / service clean-up
Hello good evening.
I wanted to ask if self-duplication of processes in which connect tasks are used is viable.
The work that is done is the generation of pdfs. Although we were working with processes that used autoduplication, the percentage had to be lowered since the cleaning service did not work. Once we lowered the autoduplication percentage, it started working except that the The problem with the cleaning service was due to a question of timing in the implementation by the service.
Thank you so much.
Greetings.
I suggest you open a technical support ticket through our website.
This type of situation will require an agent looking into your configuration and do tests with you.
