Scripting to pass value into DataMapper Field
Would like to know is there a way using “Run Script” in workflow to assign/pass value into my record field in DataMapper?
Hope someone can provide some guidance here.
Thanks in advance.
You can add Job Info values from Workflow to the Datamapper, but I am not sure if this helps you to add the right values for each record.
You might also change the metadata values after data mapping and use these values to create content.
Let me know if you want a sample for a specific approach and I will try to create that for you.
I managed to get help from FORUM. After tested. it worked.Thanks ya.
