are there some sample flows, like typical print/web etc. available?
Not yet, but we’re planning on making some available as development progresses.
Hi Phil,
Any new sample workflows you can share, just a taste would be good!! A simple csv upload to all-in-one to output a pdf.
The following is a basic example showing how to show a PDF generated by a Connect template in your browser. The flow consists of three nodes: http in, preview pdf, http response
The following assumes you run everything on your local machine (Node-RED and OL Connect software).
The flow
To install the sample flow:
The preview pdf node will show a red error triangle because it doesn’t have a Connect Server configured. Double click the node and make sure it refers to your Connect Server configuration. It requires the URL to your OL Connect Server (by default on port 9340, for example http://localhost:9340) and the credentials of the account you created on the installation of OL Connect.
People running Node-RED in a Docker Container would need to replace ‘localhost’ with the IP address of the machine running the OL Connect Server software (in my case http://192.168.2.206:9340). This would approachj would also work for users that installed Node-RED using the OL Connect Node-RED stack installer.
The Connect template
The preview node refers to the travel.OL-template but where do I put it? Well… you will need to upload the sample template to the Connect Server first in order for it to work. One way to achieve this is via OL Connect Designer (it can be automated using a Startup flow but let’s take one step at a time ):
Testing the flow
Click the Deploy button in the upper right corner of the Node-RED interface to send the flow to the Node-RED server.
The flow can be triggered in your web browser via:
http://localhost:1880/travel
You can even pass data via URL parameters: http://localhost:1880/travel?first=Peter. These parameters are captured in msg.payload, which is one of the data sources of the preview pdf node. It will feed the data straight into the Data Model of the template.
Guess that wraps it up.
Hope this is of some help,
travel.OL-template (3.4 MB)
[{"id":"4c559303926269c0","type":"http in","z":"52848583.0ca234","name":"","url":"/travel","method":"get","upload":false,"swaggerDoc":"","x":130,"y":600,"wires":[["392069e2f1b157e7"]]},{"id":"392069e2f1b157e7","type":"olcnr-preview-pdf","z":"52848583.0ca234","connect_server":"","template":"travel.OL-template","x":310,"y":600,"wires":[["e24fdfaa90386c4a"]]},{"id":"e24fdfaa90386c4a","type":"http response","z":"52848583.0ca234","name":"","statusCode":"","headers":{},"x":470,"y":600,"wires":[]}]
A flow to process an uploaded .csv file (POST) via the all-in-one could look something like the one below (left in some Debug steps).
Handling the uploaded file
It takes an uploaded csv file and writes this to the Connect File Store using the file upload node. This node returns the ID of the data file in msg.managedFileId.
When the http in node receives files the information and data is stored in msg.req.files. The change node moves the data of the first file to msg.payload (e.g. moves req.files[0].buffer to msg.payload) and stores the original name of the file in msg.basename (e.g. moves req.files[0].originalname to msg.basename). Sounds a bit heavy but the beauty of this approach is that it doesn’t leave a temp file on disk.
The file upload node is designed to either take buffer data from msg.payload or a file path in msg.filename. In this case we use the first approach so we don’t need to create a temp file and cleanup after we’re done.
Creating and downloading the output
The all-in-one node takes ID to load the data from the File Store. Once the output is ready the all-in-one node returns the ID of the output data in msg.managedFileId, the file is sitting in the Connect File Store. The file download node downloads the respective file and returns it to the http response node for download.
Sample files
Below the flow in JSON format and the template, datamapper and output preset. Use the Node-RED Import feature to add it to your flow and use Send to Server option of Connect Designer to upload the Connect resources to Connect Server.
Connect resources
Node-RED flow
[{"id":"7bd0cfc21a11cae7","type":"http in","z":"2836ae56.a71f42","name":"","url":"/csv","method":"post","upload":true,"swaggerDoc":"","x":140,"y":620,"wires":[["de58e80989760d50","335c3277e0bd2547"]]},{"id":"c20c0b3d4762e899","type":"http response","z":"2836ae56.a71f42","name":"","statusCode":"","headers":{},"x":1070,"y":620,"wires":[]},{"id":"ac19660f778f5c2a","type":"olcnr-file-upload","z":"2836ae56.a71f42","connect_server":"","filename":"","fileDuration":"temporary","name":"","x":550,"y":620,"wires":[["011077ee9ae5adf4","7d1ddbc6d3c64311"]]},{"id":"de58e80989760d50","type":"change","z":"2836ae56.a71f42","name":"","rules":[{"t":"move","p":"req.files[0].buffer","pt":"msg","to":"payload","tot":"msg"},{"t":"move","p":"req.files[0].originalname","pt":"msg","to":"basename","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":620,"wires":[["ac19660f778f5c2a","29423788e2425946"]]},{"id":"011077ee9ae5adf4","type":"olcnr-all-in-one","z":"2836ae56.a71f42","connect_server":"","dmConfiguration":"travel.csv.OL-datamapper","template":"travel.OL-template","jobPreset":"","outputPreset":"pdf.OL-outputpreset","dataStorage":"none","name":"","x":740,"y":620,"wires":[["ded88a64c7cf7cab","23b02cdeb3e9672e","6b639cd020e27ba9"]]},{"id":"ded88a64c7cf7cab","type":"olcnr-file-download","z":"2836ae56.a71f42","connect_server":"","managedFileId":"","name":"","outputType":"buffer","x":930,"y":620,"wires":[["c20c0b3d4762e899"]]},{"id":"23b02cdeb3e9672e","type":"debug","z":"2836ae56.a71f42","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":930,"y":520,"wires":[]},{"id":"6b639cd020e27ba9","type":"debug","z":"2836ae56.a71f42","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"managedFileId","targetType":"msg","statusVal":"","statusType":"auto","x":950,"y":560,"wires":[]},{"id":"7d1ddbc6d3c64311","type":"debug","z":"2836ae56.a71f42","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"managedFileId","targetType":"msg","statusVal":"","statusType":"auto","x":770,"y":680,"wires":[]},{"id":"29423788e2425946","type":"debug","z":"2836ae56.a71f42","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"basename","targetType":"msg","statusVal":"","statusType":"auto","x":560,"y":560,"wires":[]},{"id":"335c3277e0bd2547","type":"debug","z":"2836ae56.a71f42","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"req.files[0]","targetType":"msg","statusVal":"","statusType":"auto","x":340,"y":680,"wires":[]}]
Thanks Eric for the samples. I will get them downloaded and play with them.
Much appreciated!
Jim
No problem, let me know how things go. I’m currently using Node-RED + Connect as the backend for an online solution, so in the middle of this stuff.
Hello! I am working through the POST flow above and ran into an issue with the file upload node. I am getting the following error:
olconnect.error.ERR_INVALID_ARG_TYPE
Do you know what this could be coming from?
A counterpart has passed me his flow that works on his system and I am getting the same error on the same step, so I am assuming it is something to do with my Connect setup?
It would be interesting to known which version of the Connect nodes you are using. To view this info:
Node-RED menu (upper right corner) > Manage palette > Nodes > node-red-contrib-connect
Next I would check the debug log and see what msg.req.files[0] shows after the first step.
Hi Erik,
Thank you for getting back to me. The version is 0.9.6. I am attaching a screenshot of the debug.
Could you try it with the attached csv file? I wonder of the mimetype of your file is causing an issue.
travel.csv (1.3 KB)
I received the same error as above. The mimetype is also the same with the file you recently sent.
Which version of Connect are you using?
2021.1.2.2832
I have a new PC that I am going to set up with Node-Red. Hopefully it works on that system like it is on others but just curious as to what would be causing this in case we run into this again on future installs.
Hi Erik, may I know what’s the Key name to send the POST request as I am using Postman
Hi JohnLo_FXML, The key name can be anything. It will be added as a property on the item in ‘msg.req.files’ array. Below a screendump of Postman and the result in Node-RED.
Thanks Eric, able to run it accordingly.
Hi @Erik,
Just to post on this example. Tried to use the example as supplied and I get this error, see attached image. I have uploaded the template, datamapper and output creations to the workflow so should be there present. What can I do? Do I need a workflow process setup in the workflow? Or have I missed something?
Sorry missed the important bit " Choose Send to Server option from the File menu." I have seen the error of my ways
Thanks for the heads-up!
