What is the handlebars expression for accessing a Runtime Parameter within a template?
You create a custom helper:
Handlebars.registerHelper('getParam', function() {
return merge.template.parameters.myParam;
This helper returns the value of the myParam
runtime parameter.
Then you use it within a handlebars expression: {{getParam}}
When 2024.1 has been released you can simply do {{@parameters.myParam}}
. No custom helper required.
In 2023.2, if you need to access multiple parameters you could consider a parameterized custom helper:
Handlebars.registerHelper('getParam', function(name) {
return merge.template.parameters[name];
… which you can use like this: {{getParam 'myParam'}}
