can web use XML as input file when wan’t to work with rest api ?
It’s work nice in worklow but nothing appear in documentation of Rest CookBook.
Thanks;
Herve
Thanks;
Herve
Yes, as far as the REST API is concerned, all data files are equivalent.
Of course, you will have to use an XML-based data mapping configuration to properly handle it.
When I use directly by web on my server it seem to work fine and return a DataSet ID.
But when I do the request from my client, the server return a 500 status code when I wan’t to get the result :
An unspecified error occurred which was caused by LoggedApplicationException: There was an error running the data mapping process caused by MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 47 path $ (SRV000012) (SRV000001)
Then, I try to send my file to FileStore with media type text/xml and FileStore status code is 415, unsupported media type.
The only difference I saw that I’m not inside a browser when I send my requests.
All others work fine, Submit, Progress, Handshake, … Only workflow/datamining/getResult have trouble.
Thx for your Help
Herve
Problem solved.
When I submit the process, I invert the configId and the fileId in the Url
I’m not proud of this.
Hervé
