I have a question about preprocessors. Can a preprocessor be used to remove whole lines from a text input.
I have been given text data where there almost always 8 header lines which appear at the beginning of the file, but occasionally a file is supplied that only has six. Usually it is as below
The difference is lines 7 and 8. Is it possible to remove those using a script in the preprocessor?
Chris
Of course it is.
The following script replaces CRLF in the data by <br> character.
var reader = openTextReader(data.filename,"UTF-8");
var tmpFile = createTmpFile();
var writer = openTextWriter(tmpFile.getPath(),"UTF-8");
var line = null;
while((line = reader.readLine()) != null){
line = line.replace(/(?:\\r\\n)/g, "<br>");
line = line.replace(/(?:\\n)/g, "<br>");
writer.write(line);
writer.close();
reader.close();
deleteFile(data.filename);
tmpFile.move(data.filename);
You can adapt it to remove your undesired lines like so:
var line = null;
if(!(line === ':O:0' || line === ':S:0')) writer.write(line);
writer.close();
reader.close();
That’s great thank you very much. I had to adjust it slightly as it removed all the line breaks. updated script below
var reader = openTextReader(data.filename);
var writer = openTextWriter(tmpFile.getPath());
var line = null;
if(!(line === ‘
0’ || line === ‘:S:0’)) writer.write((line)+“\n”);
writer.close();
reader.close();
