Removing Custom Plugins from WorkFlow
Is there a way to remove Custom Plugins from WorkFlow. I’ve made some changes to some that I have written and would like to removed the old versions. I’ve renamed them and made them more generic instead of job specific hence the renaming.
I’ve search the install drive but can’t seem to locate the files
cheers
All workflow plug-ins should be find in folder under:
*C:\Program Files (x86)\Common Files\Objectif Lune\PlanetPress Suite 8\Plugins*
Therefore, if you delete the relevant custom plug-ins after stopping the workflow, it should be removed from workflow after the start.
Tip: See Deleting a custom plugin on the following webpage for more information:
The Plug-in Bar - OL Connect Workflow 2023.2 User Guide
Cheers, Tosuji & Marten,
This information helped.
Michael
