CTY3 Field has no data in data mapping is there a chance that i cant skip that so i can proof print ? i cant make sa proof print because my datafiel CTY3 is no data.
Set a default value for the field in the DataMapper: in the data model pane, right click on the field and select Default Value…:
That way, the field can never be empty. However, I’m not sure that’s actually the issue here. Judging from the error message, it looks like your data mapping process is attempting to go beyond the last record.
here what happen the last 2 record is empty do you i think thats a error? or do i need to change my data mapping ?
Yes, there is definitely a mistake in your Data Mapping configuration. You are probably attempting to loop on certain elements that don’t exist.
It would be easier to contact our Support Team so they can work with you to figure out what’s wrong.
Ok thanks man. i will contact later.
