When linking a database to a PSM document, the view of the PSM screen changes. Personalisation fields are almost not readable anymore. Impossible to work in the document after database (.xml) has been linked.
Latest version installed.
Can anyone suggest a solution?
Can you detail more the environment? Screenshot may help.
Does it occur with specific data or formats?
If you haven’t had any problems before, when will there be another change in the operating environment?
if you using very high resolution monitor,
try to Compatibility tab in program shortcut.
Click Change high DPI settings
check “Override high DPI scaling behavior”
Thanks.
Issue seems to be solved with changing the DPI settings as suggested. Still must test on my large monitor, but looks good for now.
