In PlanetPress Suite there is HOWTO-1505: Printing Workflow Configuration
http://help.objectiflune.com/en/knowledgebase/KB/HWT/PPW/KB1505.html
It would be nice if there was a Connect Template/Datamapper equivalent.
With a site that is migrating from v7 to Connect, they can retain the form, but for those who are starting with Connect, they can’t.
Phil
2
You could try converting the template from PPSuite’s format to Connect…
But more seriously, that’s a feature that’s been asked a few times now, it’s on our TODO list.
I created a datamapper for the config file (had to add the XML encoding) and started on a template, but ran into an issue when I try to print.
Phil
4
Take a look at this thread where a few methods are explained and which may put you on the right track.
