Printing from designer with object selected Outputs selection box.
Hi there,
Not sure if this has been pointed out as a bug before but I’m encountering this issue when printing directly from designer.
If I have an object selected on screen when I print, the output PDF includes the blue selection bounding box from the designer.
I’ve also just noted that if I have an object selected and switch to source tab I can see designer is generating html code to generate the object blue selection bounding box.
Hello @MichaelEngstrom,
Can you let us know please which OL Connect version of the Designer you have installed currently? The reason why I am asking is because this issue has been fixed in version 2024.2.n.
Fixed an issue that could cause edit helpers (for dragging and resizing) to be persisted in Templates and in some cases even appear in output. This only occurred for sections that use Handlebars and/or JavaScript resources. (93533)
Source: 2024.2.2 Release Notes
Hi Marten,
Thanks for the reply.
We are still on Version 2024.1.2.21227
Michael
