Hai all…
Why print button in the print wizard disable?
Please help…
Capture below:
Please check whether there are no required settings missing or any errors shown in the other windows by clicking on the Next > button.
Please check the settings in the other windows too by clicking on the Next > button until this button is also disabled.
Please go through the tabs in the Meta Data Options window as there seems to be an error.
When opening\creating this output preset, have you selected the correct Job preset.
The Job preset handles the passthrough of the matadata variables used in your output preset.
If you don’t select the correct job preset, the system uses the default (none) job preset, so the output preset does not receive the metadata variables used in the filename creation. And cannot print the output.
Kind regards,
Dennis Kleijne
Thanks Dennis and Marten
i have found the root couse,
