PReS Connect Service Login on As Local System Log
I changed my ‘Login On As’ to Local System.
I see the engine was executed when I the PReS Connect Service restart.
But I can’t find my Engine log in “C:\Users\Administrator\Connect\logs”
Where can I find my PReS Connect Server Engine log if I chaned 'Login On As ‘to Local System’?
That would be C:\Windows\System32\config\systemprofile\Connect\logs
I am only not certain whether you should run the PReS Connect Server service under Local System. Perhaps someone else can confirm whether this shouldn’t be a issue?
