PP7 design templates
how can i go about moving all of the designs from a PP7 application in to OL Connect without a lot of additional programming?
You cannot edit PP7 templates with OL Connect. You can use them as before in Workflow, however. You simply need to use the File | Import | Import PlanetPress Document option from the Workflow Configuration tool.
You can also import your processes by using the File | Import | Configuration components option.
gotcha, not trying to edit the PP7 designs just trying to get them in to OLC. I think these are design templates used for the client letters and what not i need to get migrated in to OLC.
