Is it possible to print such a PostScript? If the next page is blank then prints simplex, as opposed to duplex. Example - 1 full, 2 full, 3 full, 4 empty, 5 full, 6 full → then there is duplex, simplex, duplex.
Andris
Andris
The problem is that it is hard to find out if a page is completely empty. This could possibly happen in Datamapper (extract complete page and see if content is present). In Designer, duplex/simplex can be controlled via a script.
Example Script:
var section = merge.template.contexts.PRINT.sections[“myPrintSectionName”];
section.sheetConfig.duplex = true;
In my example, it turns out that you have to put page 1 duplex, page 3 simplex and page 5 duplex. But what if a blank page can be both in the middle or in the end, or both in the middle and at the end. Examples are files with six pages:
My answer was only a hint in the right direction. I dont know if its a good idea to use datamapper to check if a page is empty but I dont have any other idea to do that. But for the control have a look at Media Rotation in Sheet Configuration - OL Connect Professional - Upland OL User community.
Thats not exactly what you need but it shows how to handle such things in a designer control script.
